Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Laminar flow over a cylinder at Re=40 getting both viscous and pressure foces?
Old   April 5, 2015, 04:09
Default Laminar flow over a cylinder at Re=40 getting both viscous and pressure foces?
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hey Guys,
I hope that you are all fine. I have been working on an example about flow over a cylinder. My domain is at Rmax=10 and a cylinder radius at Rcyl=0.5 and properties of rho=1m3/kg, dynamic viscosity of 0.025 N.s/m2. I have done the grid convergence study successfully and obtained the drag coefficient at zero mesh spacing. After finishing the grid convergence, I have to prove that the pressure force is the dominant part in the drag coefficient. Even though simpleFoam provides the folder post-processing with file force in it, I am unable to filter that and prove what I mentioned previously. Is there any way to filter the data and prove that the drag coefficient comes mostly from pressure forces instead of the viscous force. I would be more than happy if someone of you could give exploitations. I am attaching the forcecoeffs.dat that I have obtained.
http://www.mediafire.com/download/24...orcecoeffs.zip
Thank you,
tareqkh is offline   Reply With Quote
Old   April 6, 2015, 02:41
Default Any Answers????
tareqkh's Avatar
CFD
Any suggestions are welcomed
Thank you,
Regarding pressure projection method for unsteady viscous compressible flow avinash87 Main CFD Forum 21 July 28, 2012 06:55
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 17:49
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
