September 8, 2015, 06:45 |
yPlusRAS error: "cannot open file"
jaydeep
Rep Power: 10 |
Currently I am running the case in OpenFOAM 2.3.0. I am having a problem calculating the y plus value. My case is in sonicfoam having Re 3e6 and I am using K-Epsilon RAS model. However, after post processing I type the command yPlusRAS in terminal, I get following error message, * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * Create time Create mesh for time = 0 Time = 0 Calculating wall distance Writing wall distance to field y Reading field U Reading/calculating face flux field phi --> FOAM FATAL IO ERROR: cannot open file file: /home/cae/OpenFOAM/cae-2.3.0/run/jaydeep/Pen_3D_4.5/constant/transportProperties at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 87. FOAM exiting * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * Can anybody suggest a possible solution to overcome this error message ? Thanks and Regards jaydeep [ Moderator note: moved post from http://www.cfd-online.com/Forums/ope...-values-2.html and deleted the duplicate posts. ] Last edited by wyldckat; October 10, 2015 at 09:30. Reason: see "Moderator note:" |
September 8, 2015, 06:51 |
#2 | |
Roman Thiele
Rep Power: 20 |
BTW, when you read your error message carefully you will see that you are missing a file which the solver needs to read. In your case transportProperties.
~roman |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
