Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
problem with foamMeshToFluent and foamDataToFluent
Like Tree1Likes
Old   June 27, 2016, 22:40
pan
Thomas pan is on a distinguished road
Originally Posted by masoudsh View Post
what do you mean "Don't use the original .msh file. "
3,Read .msh file(which is produced by foammeshtofluent, not the .msh file produced by meshing sofeware) in fluent.
Thomas pan is offline   Reply With Quote
Old   June 28, 2016, 07:59
masoudsh is on a distinguished road
I know,I did what you said
Thomas which openfoam version do you use for "foamDataToFluent"
masoudsh is offline   Reply With Quote
Old   June 28, 2016, 08:10
pan
Every version is the same。 I haven't seen errors for three versions. You run openfoam in parallel? Do you reconstructPar for results?
Old   June 28, 2016, 13:56
thomas I have a request from you
Can you show me this step in some picture?
apply the step in one of openfoam tutorial
I sincerely thank you
Old   June 28, 2016, 22:46
pan
I haven't transfered the parallel cases. It is very simple, you should check your cases and try more.
Old   September 11, 2022, 03:13
B.V
Behnam
B.V is on a distinguished road
Originally Posted by Scram_1 View Post
Hey Thomas,
I enabled the energy equation in Fluent and now I'm able to select the temperature field. However, I'm only able to 300K in the contour plot which is my inlet temperature. The velocity plot shows a boundary layer being formed at the walls and is similar to the one displayed in ParaFoam. The temperature contour in ParaFoam shows a thermal boundary layer but in the one shown by Fluent, the temperature is uniform throughout (300 K). I have changed the controlDict file as well such that the startTime is the latestTime. The .dat file generated by OpenFOAM shows that the temperature is varying from 300 K to 330 K (which is the wall temperature of the channel).
Sorry am not able to attach the .dat file and .msh file as they exceed 150 MB.
Thanks!
Ram
Hi scram,
Have you find the solution for this problem?
I would highly appreciate if you could help me?
Regards,
Behnam
B.V is offline   Reply With Quote
foamdatatofluent, foammeshtofluent
FoamDataToFluent dnomdec OpenFOAM Post-Processing 8 July 31, 2013 12:07
Suse10 FoamX problem frank178 OpenFOAM Installation 6 January 14, 2010 05:18
FoamDataToFluent Problem aganesan OpenFOAM Post-Processing 8 June 4, 2008 18:15
