Probe point by his ID (not his location)
I need to set up probe in dynamic mesh case and I want it to follow one (moving) point. Elegant way to do this might be to set the probe to point ID. Is that even possible? And if so, how can I set it up? Or, more precisely, what changes should I make in following code? functions { probes { // Where to load it from functionObjectLibs ( "libsampling.so" ); type probes; // Name of the directory for probe data name stagnationPointPressure; // Write at same frequency as fields outputControl timeStep; outputInterval 1; // Fields to be probed fields ( p ); probeLocations ( (0 0 0) ); } } |
Any luck? |
Unfortunately no.
But at least now we are two. If you find an answer to this, please post it here. I will do the same. |
I guess you are using 6DOF solver, cause this is the case when the motion is undefined. I use the information displayed in the log file of the solver while running the case. In the log file you have something like this: Quote:
Hope it helps you. |
Dear all,
Use " fixedLocations false; " refer post no. 4 here: https://www.cfd-online.com/Forums/op...-boundary.html Regards, Mohamad |
