February 2, 2016, 07:40 |
Probe point by his ID (not his location)
Rep Power: 11 |
I need to set up probe in dynamic mesh case and I want it to follow one (moving) point. Elegant way to do this might be to set the probe to point ID. Is that even possible? And if so, how can I set it up? Or, more precisely, what changes should I make in following code? functions { probes { // Where to load it from functionObjectLibs ( "libsampling.so" ); type probes; // Name of the directory for probe data name stagnationPointPressure; // Write at same frequency as fields outputControl timeStep; outputInterval 1; // Fields to be probed fields ( p ); probeLocations ( (0 0 0) ); } } |
February 14, 2016, 08:16 |
#2 | |
Any luck?
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
February 14, 2016, 10:58 |
Rep Power: 11 |
Unfortunately no.
But at least now we are two. If you find an answer to this, please post it here. I will do the same. |
February 14, 2016, 12:36 |
#4 | |||
I guess you are using 6DOF solver, cause this is the case when the motion is undefined. I use the information displayed in the log file of the solver while running the case. In the log file you have something like this: Quote:
Hope it helps you.
August 6, 2018, 10:38 |
Mohamad
Rep Power: 9 |
Dear all,
Use " fixedLocations false; " refer post no. 4 here: probe/sample pressure on moving boundary Regards, Mohamad |
[General] Probe location in a script | Mc Fly | ParaView | 1 | September 15, 2015 02:11 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
[ICEM] Reply script in ICEM CFD location use location of geometry point | karamski | ANSYS Meshing & Geometry | 2 | August 13, 2014 11:08 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
