[OpenFOAM] How to slice internalMesh with stl file, or how to elevate ground surface [paraView] |
February 17, 2016, 01:57 |
gereksiz
Rep Power: 11 |
I'm using paraView and I need to slice the internalMesh with a stl file like normal slice operation but a different stl file instead of a plate. In other words I need to elevate my bottom surface to see what is happening exactly a certain height above the ground but the ground varies a lot so I can't do it manually. I've been searching but I couldn't find anything about it. I can do it with enSight so I think I should be able to with paraView too. Regards |
February 18, 2016, 04:10 |
The filter you are looking for is resample with dataset. This requires an input (internalMesh) and a source: your stl file. You could also use the transform filter on a patch to move it a certain distance and use that as your source. Regards, Tom |
February 24, 2016, 07:52 |
gereksiz
Rep Power: 11 |
Thanks a lot, it works as I want!
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
