Plotting sampleDict values and problems with probeLocations format
2 Attachment(s)
Hi everyone,
I have been using probes and probeLocations for some time and getting the data into a csv file using pyFoam: Code:
pyFoamTimelinePlot.py --fields=<field> --basic-mode=lines --csv-file=<field>.csv postProcessing/ I have no idea why I would have it this time... am totally stumped on this!! I tried to work around it by using the sample utility but this creates a new directory for every time step. How would I combine that data from all of the time steps into one file so I can plot over time? I would really appreciate any help on using these utilities, totally confused because I did have this all working well. |
Issue solved, Ariel, finally?How?
Hi there @gned,
Which version of openfoam are you using? I discovered that the format that the data for probeLocations is written changes in (I think) version 2.4.0, which makes pyFoamTimelinePlot not work. I resolved this by simply using the source code from an older version (OF 2.3.0) to write the data using probeLocations and then pyFoamTimeLinePlot worked again! A little bit of a cheating fix, but it worked for me Hope that helps, Ariel |
