Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Plotting pressure on cylinder
Like Tree2Likes
  • 2 Post By davibarreira
Old   December 22, 2015, 10:41
Default Plotting pressure on cylinder
Niels D
Slein is on a distinguished road
I made a model to determine te pressure around a cylinder in a uniform flow. Is there a possibility to plot the pressure for every point around the cylinder. For example the pressure in function of the polar coordinate theta?
Thanks in advance,
Niels
Slein is offline   Reply With Quote
Old   January 15, 2016, 19:34
Davi Barreira
davibarreira is on a distinguished road
I dont know if you are still interested on this, since it has been almost a month. But anyways, yes there is a way, but the way I do it you need some programming. Well, for me, I like to use python for postprocessing, so here is how you can do this.
First, you need a sampleDict so you can sample the cylinder surface by using the utility "sample" (once you have the sampleDict in the system folder, just run "sample" from the terminal, you can find examples of the sampleDict in the motorbike tutorial). After you done this, you got the pressure values for your cylinder, what is left to do is to transform the results in polar coordinate. This is now simple math, since you have the x, y and z coordinates of each point.
Hope this helps. If you need more specifics, just let me know.
davibarreira is offline   Reply With Quote
Old   December 17, 2020, 07:02
Default plotting pressure variation over cylinder
vikrant kumar jaiswal
Vikrant kumar jaiswal is on a distinguished road
I need to know how to plot pressure vs theta?
so please help me
Vikrant kumar jaiswal is offline   Reply With Quote
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
pressure distribution and drag for a surface piercing cylinder in OCF kevinmccartin FLUENT 1 May 19, 2016 12:46
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
UDF to control Static Pressure (in cylinder) James FLUENT 0 July 20, 2004 07:54
