Calculating the static pressure on HAWT blades? |
April 10, 2016, 21:09 |
CFD
Rep Power: 16 |
Hello Fomers,
I hope that you are all well. I have been trying to verify some resutls on a paper about wind turbines using AD model. The code has to file, sampleDictForce and velocity. I have never used this utility before, but anyway I intuitively used the command "sample" after finishing the simulation. The command sample has given me the following; "From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 87." I don't know what exactly whether this from the version that I am using or misinterpretation of using this utility. Has anybody of you used this utility for similar purposes? I would really appreciate any help or document deals with similar post-processing. Thank you all, |
April 10, 2016, 21:57 |
Answer!
CFD
Rep Power: 16 |
Search for an example sampleDict file in OpenFOAM directory and copy it to system and adjust it.
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Static Pressure vs Hydrostatic Pressure | MissCFD | CFX | 3 | August 12, 2014 23:29 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
