Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
cuttingPlane with cyclic BC
Old   August 14, 2013, 05:20
Smile cuttingPlane with cyclic BC
Julia Docampo
Xulia is on a distinguished road
Dear Foamers:
I have been using OF-2.1.x for the past two months, forgive me if my problem is very easy/obvious to fix. I am running simulations on open channel so my BCs are cyclic in the spanwise direction. I am generating turbulence (using LES) that I will save as initial conditions for the next simulation: turbine performance. I want to save a plane from the middle of the channel (normal to streamwise direction) containing data of U, p, U_0, etc during different times, that I will use as inlet for the turbine simulation. I found that cuttingPlane can do that and I imitated the case incompressible/simpleFoam/motorbike.
This is my cuttingPlane function:
cuttingPlane
type surfaces;
functionObjectLibs ("libsampling.so");
outputControl outputTime;
surfaceFormat vtk;
fields ( p U U_0 nuSgs);
interpolationScheme cellPoint;
surfaces
yNormal
type cuttingPlane;
planeType pointAndNormal;
pointAndNormalDict
basePoint (2 1 1);
normalVector (0 1 0);
interpolate true;
When I run the solver (channelFoam), it gives me this error:
--> FOAM FATAL ERROR:
Unhandled coupledPolyPatch type cyclic
From function isoSurface::collocatedFaces(const coupledPolyPatch&) const
in file sampledSurface/isoSurface/isoSurface.C at line 94.
FOAM aborting
I can't avoid the cyclic BC, since it represents the width of my channel and I need it to be that way... I am confused because I went through the cuttingPlane case (/src/sampling/cuttingPlane) and read all the functions and I don't know when isoSurface.C is called... I can't find that line....
Has anybody succeed in using cuttingPlane involving cyclic BCs?
Is there an alternative way to save a plane during simulations?
Many thanks!!
Xulia is offline   Reply With Quote
Old   April 26, 2016, 07:27
sandy
vishwakarma is on a distinguished road
Originally Posted by Xulia View Post
Dear Foamers:
cuttingPlane
type surfaces;
surfaceFormat vtk;
surfaces
yNormal
type cuttingPlane;
pointAndNormalDict
basePoint (2 1 1);
interpolate true;
FOAM aborting
Many thanks!!
Did you get the answer to your question? I am facing the same problem and not able to resolve it.
vishwakarma is offline   Reply With Quote
channelflow les, cuttingplane, cyclic bc, runtime postprocessing
Why Menter's SST model low-Re issue has not been seriously investigated? vkrastev OpenFOAM 58 January 8, 2018 15:20
[mesh manipulation] Cyclic Mesh Error vbchris OpenFOAM Meshing & Mesh Conversion 4 November 15, 2012 13:04
Cyclic bc. and overlapGgi Pekka OpenFOAM 12 February 15, 2012 07:10
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
