Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Error when getting kappaEff from turbulenceFields
Old   August 18, 2023, 11:19
Default Error when getting kappaEff from turbulenceFields
Agustín Villa
agustinvo is on a distinguished road
I am trying to get the kappaEff field from my channel flow simulation on OpenFOAM 11 (I attach the case) by using the turbulenceFields function object:
foamPostProcess -latestTime -solver fluid
However I get the next error:
--> FOAM FATAL ERROR:
Invalid field selection
    From function virtual bool Foam::functionObjects::turbulenceFields::execute()
    in file turbulenceFields/turbulenceFields.C at line 269.
FOAM exiting
As far as I see in the code, at the execute function there is an if statement in function of the use of a fluidThermophysicaltransportModel, which I use (eddyDiffusivity model). However I cannot reach that code block (where kappaEff is processed) but the next one, that only requires a compressible momentum turbulence model.
Have you ever tried to get kappaEff from this functionObject? Am I missing something in my dictionary or there is a bug?
Regards
Agustín
agustinvo is offline   Reply With Quote
Old   February 23, 2024, 01:53
Agustín Villa
This problem has been solved on the commit
https://github.com/OpenFOAM/OpenFOAM...3c7e86bddaeb92
kappaeff, openfoam, turbulencefields
turbulenceFields in controlDict not working (apparently) pmarreiro OpenFOAM Pre-Processing 2 January 14, 2018 07:13
HeatFlux in buoyantBoussinesq stawrogin OpenFOAM 22 August 17, 2011 09:20
