Home > Forums > OpenFOAM Post-Processing
No output produced
Old   May 7, 2016, 13:48
Default No output produced
Justin Maris L. Natividad
Juzzvy is on a distinguished road
Good day. I copied the tutorial on motorbike and I used my model to test it. upon running allrun, everything seems fine. After the run, I tried to use reconstructPar to see the results in each timestep, but an error occurs. Also, in the folder, there is no postProcessing folder, and upon opening paraview, there is no results for p and U. How can I fix this problem? Thank you for the consideration
Juzzvy is offline   Reply With Quote
Old   May 7, 2016, 17:49
Default Error?
Maryam
Persia is on a distinguished road
What is the error message?
Persia is offline   Reply With Quote
Old   May 8, 2016, 11:17
I checked the log.simplefoam it says that there is an error in the patch field. Anyways I checked the snappyHexMeshdict and found out that the patch field name is different for the patch in the variable p U etc. I corrected it and it worked. But still thank you
Thread Tools
Trackbacks are On
No *.plt or *.vtk output files produced Vartan SU2 Installation 8 October 18, 2016 02:25
outputTime in Swak function immortality OpenFOAM Post-Processing 16 February 14, 2016 17:02
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 06:16
RNG diverged during the analysis the flow over a multi element airfoil, why? s.m OpenFOAM Running, Solving & CFD 0 August 5, 2013 08:39
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
