Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Visualizing two fields
Old   June 4, 2016, 20:02
Default Visualizing two fields
anonymous
cute is on a distinguished road
Hi there,
I have two field values that I want to visualize at the same time. Say I have fields X and Y, how can I run animation to see both at the same time in paraView?
Any idea and suggestion or comment?
Thanks.
cute is offline   Reply With Quote
Old   June 5, 2016, 14:16
Smile
Hesam
rapierrz is on a distinguished road
Hi cute,
you can define a new custom filter in paraView.
When you define a new custom filter you can show any field in first filter
and another field in second filter and ... .
rapierrz is offline   Reply With Quote
Old   June 5, 2016, 17:30
anonymous
Thanks rapierrz for the reply.
What filter should I need to use. I am new and still learning.
So far I tried to load data two times in pipeline and used translate option to translate shapes. It works with surface plot but does not work with volume.
I have my 3D data in VTK format. When I load it, I visualize it with volume option (not surface). If you can elaborate more, that will be helpful.
Thanks.
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
multiphaseEulerFoam: efficient way of implementing fields for all phases maybee OpenFOAM Programming & Development 0 January 23, 2014 04:16
a reconstructPar issue immortality OpenFOAM Post-Processing 8 June 16, 2013 11:25
an odd(at least for me!) reconstructPar error on a field immortality OpenFOAM Running, Solving & CFD 3 June 3, 2013 22:36
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
