postProcessing only in certain area
Hello all,
i'm relatively new to OpenFoam and work with OF1.7 (because of validation reasons). I generated a mesh, decomposed it and ran the solver on 200 CPUs. Everything worked fine. Because of the huge amount of data i want to postProcess only a certain area of the pressure Field. My idea would be to generate a field with 1's in the area i want to postProcess and 0's everywhere else. Afterwards somehow multiply this new field and the pressure Field, so only the pressure Field in the area of interest is left over. Is there a way to achieve this while decomposed (i would rather not reconstruct 1000 timesteps)? Or is there a different solution to my goal? I have already trouble using setFields while the case is decomposed.. Can anyone help? Best regards, Max |
Hello, you can reconstruct your case for only latest time step if you want, not for whole time steps.
reconstructPar -latestTime If you do not want to reconstruct even for the latest time step, you need to open your case with decomposed option of ParaView. |
