Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Can I get OpenFOAM to Calculate Energy Flux for me?
Old   September 13, 2016, 08:21
Default Can I get OpenFOAM to Calculate Energy Flux for me?
Evan
k13113y is on a distinguished road
Hi all,
I'm running a simulation that propagates internal waves through a stratified fluid and I want to calculate the energy flux at various points throughout my domain over time.
The formula for energy flux is simply J = pU and I already have output files for p and U for each time step.
My question is, how do I get OpenFOAM to multiply pressure and velocity and generate a new output file called "energyFlux"?
Thanks
k13113y is offline   Reply With Quote
Old   September 13, 2016, 08:40
Evan
So far I have:
volVectorField
    IOobject
        "energyFlux",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::NO_WRITE
    p*U
written into the createFields.H file of the interDyMFoam Solver. But I'm unsure of whether this is the right format and how I should recompile the solver.
Old   September 13, 2016, 09:18
akidess's Avatar
Anton Kidess
foamCalc multiply p U:
https://openfoamwiki.net/index.php/Contrib_foamCalcEx
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   September 13, 2016, 09:22
g.freeman is on a distinguished road
Originally Posted by k13113y View Post
So far I have:
volVectorField
    IOobject
        "energyFlux",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::NO_WRITE
    p*U
Hello, the correct versione should be like:
const vector energyFlux = p*U
volVectorField energyFlux
    IOobject
        "energyFlux",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::AUTO_WRITE
    dimensionedScalar("energyFlux",p.dimension*U.dimension,)
You need to specify AUTO_WRITE otherwise it will not write anything. You're right when you say to write it into createField.H file; for recompiling the solver just go into the solver folder, in you case $FOAM_SOLVERS/multiphase/interFoam/interDyMFoam, and type wclean, then wmake.
Hope this is useful for you
g.freeman is offline   Reply With Quote
Old   September 13, 2016, 09:24
Evan
hey this is great!! Many thanks
My only question now is: does it matter where I place it in the createFields.H file? I'm assuming it must be after p and U...
Old   September 13, 2016, 09:37
It doesn't matter since it only reads the fields and then creates the output files.
In the past I've never cared where I write and it has always worked
EDIT: there's a mistake in the last line of the code: after p.dimension()*U.dimension(), after the comma you need to write 0.0.
dimensionedScalar('energyFlux",p.dimension()*U.dimension(),0.0)
If you prefer you can also specify the dimensions as dimMass/dimTime/dimTime/dimTime, which is pU dimensions.
Old   September 13, 2016, 09:45
Evan
Hmm I seem to be getting an error when I try to compile.
Info<< "Reading field energyFlux\n" <<endl;
const vector energyFlux=p_rgh*U;
    IOobject
        "energyFlux",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    dimensionedScalar("energyFlux",p_rgh.dimension*U.dimension,)
In file included from /opt/openfoam4/src/OpenFOAM/lnInclude/postProcess.H:129:0,
                 from interEnergyFluxFoam.C:58:
./createFields.H: In function ‘int main(int, char**)’:
./createFields.H:32:30: error: conversion from ‘Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >’ to non-scalar type ‘const vector {aka const Foam::Vector<double>}’ requested
./createFields.H:36:5: error: conflicting declaration ‘Foam::volVectorField energyFlux’
./createFields.H:32:14: note: previous declaration as ‘const vector energyFlux’
./createFields.H:43:42: error: ‘Foam::volScalarField {aka class Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ has no member named ‘dimension’
./createFields.H:43:54: error: ‘Foam::volVectorField {aka class Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>}’ has no member named ‘dimension’
./createFields.H:43:22: error: expected primary-expression before ‘(’ token
./createFields.H:43:64: error: expected primary-expression before ‘)’ token
In file included from interEnergyFluxFoam.C:67:0:
/opt/openfoam4/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/interEnergyFluxFoam.o' failed
make: *** [Make/linux64GccDPInt32Opt/interEnergyFluxFoam.o] Error 1
I tried removing the dimension and the const variable and the application compiled but the file never appeared in the output.
Old   September 13, 2016, 09:49
I think it is because one argument in dimensionedScalar function is missing, check the edit at my last post
Old   September 13, 2016, 09:56
Evan
ah sorry, it still has a similar error. I'm using OF 4.0 but I don't think that should matter.
     dimensionedScalar("energyFlux",p_rgh.dimension()*U.dimension(),0.0)
./createFields.H:43:56: error: ‘Foam::volVectorField {aka class Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>}’ has no member named ‘dimension’
Old   September 13, 2016, 12:15
Evan
Okay I have managed to make it work.
Here is what I added to my createFields.H file:
// Adding a new field: energyFlux
    IOobject
        "energyFlux",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    p_rgh*U
and I also made a new file called energyFluxEqn.H inside the interDyMFoam folder (which is the solver I am using). That file is simple and looks like this:
    energyFlux == p_rgh * U;
Then I ran:
wclean
wmake
And now each write interval contains a file called energyFlux.
How to calculate the flux of this term grad(alpha1)*alphaf*U? keepfit OpenFOAM Running, Solving & CFD 2 June 9, 2016 15:08
How to calculate the flux of this term grad(alpha1)*alphaf*U? keepfit OpenFOAM 0 June 6, 2016 10:42
Not able to calculate wall heat flux in cfd post vikasy123 FLUENT 1 November 21, 2015 00:44
Compare 2D axi-symmetric and 3D. Is OpenFOAM calculate the velocity wrong? RalphS OpenFOAM 6 November 13, 2010 20:51
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 13:22
