November 2, 2016, 21:07 |
funkyDoCalc in cyclic system
Su Choi
Rep Power: 10 |
I am trying to analyze results from openfoam calculation using funkyDoCalc.
ex) funkyDoCalc -time 0.65 calfile It works well in normal full 3d case, but in periodic system(there are 2 cyclic patches; cyclic_a, cyclic_b) funkyDoCalc does not work and shows error message like ----------------------------------------------------------------------- --> FOAM FATAL IO ERROR: keyword rotationAngle is undefined in dictionary "::cyclic_a" file: ::cyclic_a from line 67 to line 75. ----------------------------------------------------------------------- how can I solve this problem?? |
November 7, 2016, 16:41 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
BTW: Foam-version and swak-version are also important. AND: was the case written with the same Foam-version that you're currently using?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
cyclic, funkydocalc, rotationangle, swak4foam |
Display Modes | |
Why Menter's SST model low-Re issue has not been seriously investigated? | vkrastev | OpenFOAM | 58 | January 8, 2018 15:20 |
which windows operating system for multi-core system? | Chris Lee | Hardware | 11 | December 14, 2014 07:26 |
simpleFoam + cyclic pipe = unstable? | RodriguezFatz | OpenFOAM Running, Solving & CFD | 9 | December 1, 2014 05:28 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
Cyclic boundary matching - help needed | Robert_B | STAR-CD | 5 | June 15, 2011 08:03 |
