plot of wall shear stress and turbulent properties (average of u'u', v'v', u'v' ) |
November 20, 2016, 15:07 |
Saurav Kumar
Rep Power: 9 |
i am beginner in OpenFoam CFD simulation and learning from youtube tutorial, i learned case setup and simple post processing in Paraview.
i used k-e and kw model but i cant able to plot fluctuating (prime) quantities, in paraview there is only mean pressure and velocity are available. how can i create some variable that is not default in solver, i want to plot 1. wall shear stress or skin friction coefficient, coefficient of pressure, drag and lift coefficient. 2. turbulent properties (average of u'u', v'v', u'v' ) please help me, i cant able to plot all these result. Thank you Saurav kumar |
December 28, 2016, 08:24 |
DimitriF
Rep Power: 9 |
Hey Foamers,
I have the same issue. A reply to this post would be really helpful. Regards, Dimitri |
December 29, 2016, 02:52 |
Rep Power: 15 |
When using RANS simualtions with k-epsilon or k-omega you are not calculating the Reynolds stresses - you are only modeling the fluctuations by the k-transport equation. Thus, you have no results for u'u' etc.
Pressure is calculated - in order to get the pressure coefficient you need to divide by the dynamic pressure of the flow. You can do that in Paraview, check some other threads here in the forum for that, or use the OpenFOAM tutorials. Drag and lift coefficient can be automatically calculated during runtime by a functionObject in the controlDict file. Again, search the forum. Hope that helps. If you have problems even after searching for the solutions let me know. |
December 29, 2016, 03:18 |
Saurav Kumar
Rep Power: 9 |
Hi Bazinga,
i can use wallShearStress to calculate stress and Skin Friction Coeff, it is working in simpleFoam but it is not working in icoFoam, what should i do? i added energy equation in icoFoam and compared temperature and velocity profile at various section in streamwise direction with the fluent result both are exact same but the problem is i dont know to to calculate local Nusselt number at wall. how can i calculate local Nusselt Number? Thank you Srv |
December 29, 2016, 03:23 |
Rep Power: 15 |
I have not yet calculated the Nusselt number but a simple google search gave me this report:
http://www.tfd.chalmers.se/~hani/kur...ssonReport.pdf With regard to wallShearStress what is the error? |
December 29, 2016, 04:02 |
Saurav Kumar
Rep Power: 9 |
icoFoam -postProcess -func wallShearStress it gives me
Usage: icoFoam [OPTIONS] options: -case <dir> specify alternate case directory, default is the cwd -noFunctionObjects do not execute functionObjects -parallel run in parallel -roots <(dir1 .. dirN)> slave root directories for distributed running -srcDoc display source code in browser -doc display application documentation in browser -help print the usage Using: OpenFOAM-4.1 (see www.OpenFOAM.org) Build: 4.1 --> FOAM FATAL ERROR: Wrong number of arguments, expected 0 found 1 Invalid option: -postProcess Invalid option: -func FOAM exiting |
December 29, 2016, 06:15 |
Rep Power: 15 |
You should start to first search for your problem in this board, then google and then ask your questions in your own threads.
One simple search, again, provided this link: postProcess Utility: icoFoam -noFunctionObjects Why?How? There you will find an answer to your problem. Also, please do not create multiple threads/post with the same question. I found your thread (wallShearStress doesn't work in new solver (energy eq added in icoFoam)) while searching for your problem. |
December 29, 2016, 06:21 |
DimitriF
Rep Power: 9 |
Hey Bazinga,
Thank you for your thorough explanation! I have some results for the Reynolds stress from experiments and other numerical simulation and I thought I can get something out of OpenFOAM for comparison. You are right, the solved equations just give the variables you solve for. Maybe I can do some manual calculation with the outputted data to get the Reynolds stress. Getting the coefficients works! Cheers, Dimitri |
December 29, 2016, 06:28 |
#9 |
Rep Power: 15 |
Maybe you can validate the turbulent kinetic energy k. k = 0.5*(U'2+V'2+W'2) (check: https://en.wikipedia.org/wiki/Turbulence_kinetic_energy). If you know the RE-stresses from experiment, you can calculate k from the experiment and then validate with your simulation.
December 29, 2016, 07:27 |
#10 |
DimitriF
Rep Power: 9 |
That would be an idea! I will try to do that for sure to have something for comparison.
I have an understanding problem though...if I use e.g. the Spalart Allmaras turbulence model, is there a way how I can get a value for my turbulent kinetic energy k? In my understanding, OpenFOAM does not compute k when the SA model is used. Dimitri |
December 29, 2016, 07:43 |
#11 |
Rep Power: 15 |
I would use the k-omega one, but if you need S.A. there is one way, but I don't think it is really accurate and never tried it.
IIRC S.A. calculates the eddy viscosity by means of a length scale, which is defined by the user, and k, which is modeled directly from this length scale in order to close the system of equations. Look up the relation between those 3 values and I guess you get a k, but as said earlier,I never tried it. |
December 29, 2016, 10:44 |
#12 |
DimitriF
Rep Power: 9 |
That would be one way to get the kinetic energy. However, since Boussinesq approximation is used, you can calculate a posteriori the Reynolds stress from known, transported quantities. This calculation could be done manually.
However, I found two other ways how to get it directly from openFoam. The first way is to use the integrated post processing tools of OpenFOAM (http://cfd.direct/openfoam/user-guide/post-processing-cli/#x31-2270006.2).This gives the Reynolds stress tensor. The turbulent kinetic energy is proportional to the trace of the tensor. The second way is to use a tool someone wrote (Utilities: post average turbulence fields and create turbulence fields for LES). I haven't tried it though. This might also help you Saurav kumar. Thank you for pointing me in the right direction Bazinga! :-) |
December 29, 2016, 11:10 |
#13 | |
Rep Power: 15 |
Divergence in AMG solver! | marina | FLUENT | 20 | August 1, 2020 11:30 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
plot of wall shear stress and turbulent properties (average of u'u', v'v', u'v' ) | srv537 | OpenFOAM Pre-Processing | 0 | November 20, 2016 15:05 |
Wall Shear Stress: Ansys Fluent | chowdhury | FLUENT | 3 | November 17, 2015 00:09 |
Turbulent shear stress and wall shear stress | mejahan | CFX | 3 | September 7, 2013 00:44 |
