Reported phi values exactly twice as high as expected
2 Attachment(s)
Hello everyone,
I am new to OpenFoam and today I was getting familiar with the run-time monitoring possibilities when I spotted some strange results. I have spent quite some time trying to figure this out with no luck, but I believe I have now narrowed the problem down to the point where a more experienced user could easily tell me what's going on. I attach here two small cases, ready to go on v1606+ (./Allrun).Those are somewhat modified versions of the multiRegionHeater tutorial case: - case 1 is a transient run, very similar to the original tutorial provided with my version of OpenFOAM (v1606+ on Windows). - case 2 is a steady-state analysis of the the same problem. For both case I monitor what is going on at minX on the water side (inlet, fixed velocity), and obtain the following results: Case 1: Code:
- Total area: 4.00000000e-03 Code:
- Total area: 4.0000000e-03 However, I can't understand how Phi is computed in case two. A volumetric flow rate would explain the different order of magnitude but the reported flow rate would still be twice as high as I would expect. I have tried to run case 2 on a single processor, which didn't change the results. I would be extremely thankful if someone could have a look at this. Cheers /Jay |
Update
I believe I have identified what the problem was:
As a consequence of some shameless copy-pasting of the fvSolution files from a steady-state tutorial, and although I had defined the fluid density as constant (1000 kg/m3), those SIMPLE settings were limiting the density to 2 kg/m3. Lesson learned... :o Code:
SIMPLE |
