Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Loop over cellZone from actuator disk
Old   November 29, 2016, 19:48
Default Loop over cellZone from actuator disk
Luis Eduardo
lebc is on a distinguished road
Hi guys,
I'm working with an actuator disk (actuationDiskSource) to represent a wind turbine, and I need to calculate some quantities, for example the extracted power on this disk.
First question is: is there an easy way to calculate it already native on OF 3.0.1?
Second question: I've done some research, and the power could be calculated summing the contribution of each cell of the disk, and it depends on the wind speed, density, cell area and "a" (1-Cp/Ct), so I would need to calculate it on each cell and sum it. Do you have any clue about how can I do this?
My disk is defined in topoSetDict (attached file) as a cellZone, I thought about using a volAverage or something like this from functionObjects, but I actually didn't have time to try it!
Thank you in advance!!!
lebc is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
