Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
wrong value of forces in 2D simulation?
Old   November 29, 2016, 23:54
Default wrong value of forces in 2D simulation?
Vu
DoQuocVu is on a distinguished road
Hi everyone,
I'm running a 2D case of fanwing model and trying to export the forces value by using function object. Here i have the forces.dat file after running but i wonder if there's something wrong with it.
Why the force value in the Z direction is not zero since this is a 2D case?
another thing is the drag force has negative mean value? that means the wing has more thrust and it can fly faster and faster which is ridiculous.
i'm so struggle now, so thanks for any suggestion of you guys
This is my forces.dat file:
# Forces
# CofR : (0.000000e+00 0.000000e+00 0.000000e+00)
# Time forces(pressure viscous porous) moment(pressure viscous porous)
6.803974e-05 ((4.536716e+00 4.721208e+00 -5.066507e-19) (2.330434e-01 1.298793e-01 5.368491e-15) (0.000000e+00 0.000000e+00 0.000000e+00)) ((-4.721208e-02 4.536716e-02 3.078094e+00) (-1.298793e-03 2.330434e-03 5.924120e-02) (0.000000e+00 0.000000e+00 0.000000e+00))
2.098508e-04 ((1.065411e+01 3.749370e+00 3.224268e-19) (9.451385e-02 2.804937e-02 1.505337e-15) (0.000000e+00 0.000000e+00 0.000000e+00)) ((-3.749370e-02 1.065411e-01 5.898828e+00) (-2.804937e-04 9.451385e-04 2.454231e-02) (0.000000e+00 0.000000e+00 0.000000e+00))
DoQuocVu is offline   Reply With Quote
Old   December 17, 2021, 06:44
F
fran.cesc is on a distinguished road
Those forces are zero.
The forces are:
-5.066507e-19 (z component) is basically zero compared to 4.536716e+00 and 4.721208e+00 (x and y component)
5.368491e-15 is basically zero compared to 2.330434e-01 1.298793e-01
then within the other brackets are moments, so you want to have zero in x and y, but not in z. And you kind of have that:
-4.721208e-02 4.536716e-02 are way smaller than 3.078094e+00
fran.cesc is offline   Reply With Quote
Wrong forces coming from forces function object in controlDict Jason_Duguay OpenFOAM Post-Processing 0 April 13, 2016 09:07
Forces calculation after simulation has finished miuzZz OpenFOAM Post-Processing 5 August 20, 2015 12:36
Pressure and density values to compute forces fernexda OpenFOAM Post-Processing 2 March 6, 2015 03:39
Wrong forces on a 2D airfoil using interPhaseChangeFoam Artur OpenFOAM 0 August 7, 2013 11:38
Resume Transient simulation HMR CFX 1 June 28, 2011 21:13
