Home > Forums > OpenFOAM Post-Processing
Particle tracking visualization in paraview
Old   February 1, 2017, 04:23
Unhappy Particle tracking visualization in paraview
Kevin
leexit is on a distinguished road
Sponsored Links
Dear Foamers,
I am currently working on discrete particle modelling, and I need som help.
I use OF 4.0, and ran the "cyclone" case using MPPICFoam. After running the simulation, I tried to visualize the particle moving inside the cyclone, but need some help in order to do this. I opened the kinematicCloud.vtk from the VTK/Lagrangina, but not really sure what I should do next.
Could you guys give me some help (step by step instruction will be highly appreciated..)? Eventually, I wanted to end up with nice image on the DPM section in OpenFOAM webpage. http://openfoam.org/release/2-3-0/dpm/
Regards,
Kevin
leexit is offline   Reply With Quote
Sponsored Links
Old   February 1, 2017, 23:01
Declan
decah is on a distinguished road
Hi Kevin
Have you looked at this tutorial?
They give a step by step post-processing procedure for the case you're interested in
decah is offline   Reply With Quote
Old   February 2, 2017, 05:12
vidyadhar
vidyadhar is on a distinguished road
Dear Kevin,
You can load the <casename>.foam file twice into paraview and then do the following process
1. Open <casename>.foam file in paraview and use the filters such as Extract Surface followed by Feature Edges. Or you can use a single filter Extract Edges.
2. Then reload the same <casename>.foam file and go to a time step where lagarangian/kinematic/bubble cloud is seen under Mesh Parts. Check the cloud under Mesh Parts. Then, use the filter Extract Block. Then check the kinematiccloud. Then you take a glyph and visualize the particles.
This info is available in some of the threads online. I hope this is what you are trying for.
In case you are trying to know about pathlines/particle paths/tracer etc., I am unaware of that too. Please let me know if you come across.
Regards,
vidyadhar
vidyadhar is offline   Reply With Quote
Old   February 6, 2017, 12:22
Smile
fjby is on a distinguished road
so perhaps there is a easier way to visualize the particles in ParaView.
Load your model in Paraview by typing in the terminal or comand window:
>>run
>>cd cyclone
>>paraFoam &
and then press Apply -> simulate a few time steps by press the Play button (green) -> Press Pause-Button after a few time steps -> then will appear in the Mesh Parts under Properties "kinematicCloud - lagrangian" -> select kinematicCloud - lagrangian -> deselect internalMesh -> press Apply -> then only the particles appear -> then press Play-Button and you will see like the particles are moving .
Perhaps someone of you others know how to get the "alpha" (particulate volume fraction) like it is shown in the post "OpenFOAM 2.3.0: Discrete Particle Modelling" or how to modify paraView respectivily the source file (e.g. kinematicCloud Properties) - it would be a big help for me.
Perhaps it would be the opposite of "alpha.air" in the Volume Fields.
If someone know it how to visualize the "alpha" I will appreciate it very much .
I'm using OpenFoam 4.0 with ParaView 5.0.1 in Ubuntu 16.04.
Kind regards.
Felix
fjby is offline   Reply With Quote
Old   June 20, 2017, 03:11
Fengli Shen
qiang92 is on a distinguished road
Originally Posted by decah View Post
Hi Kevin
I found the tutorial which I am interested in.
qiang92 is offline   Reply With Quote
Thread Tools
Trackbacks are On
How to do particle tracking animation with Paraview? John.I OpenFOAM Paraview & paraFoam 3 June 24, 2015 09:45
Particle Tracking in ParaView for Non-Lagrangian Solvers Cyberholmes OpenFOAM Paraview & paraFoam 1 March 20, 2014 04:52
Particle tracking INTEGER limitation warning Peter023 FLUENT 0 June 24, 2013 03:59
DPM particle tracking sajeesh FLUENT 0 May 12, 2013 02:29
Number density tracking rather than particle tracking Rebecca Main CFD Forum 2 April 23, 2009 12:52
Sponsored Links
