Home > Forums > OpenFOAM Post-Processing
high drag Coefficient 2D airfoil
Old   February 13, 2017, 08:21
Default high drag Coefficient 2D airfoil
bye bye my blue
bye bye my blue is an unknown quantity at this point
I'm simulating 2D airfoil..
Governing eqn is kEpsilon
y+ min : 6.96 max = 30.79859 average = 15.6028
and mesh is generated by salome (viscous layer =0.03 and distance:0.0006)
at (http://www.pointwise.com/yplus/), i used 0.0006
xfoil naca0015 Cd = 0.00579 and mine is 0.048
I don't know what is the problem..
here are mesh picture and 0,system,postprocess folders
Thanks
bye bye my blue is offline   Reply With Quote
Old   February 15, 2017, 09:57
Jack80 is on a distinguished road
Drag prediction is strongly dependant on the resolution of the viscous layer. K-epsilon model uses wall-function to model this region (30<y+ <300) and drag is not correctly predicted.
I suggest you to use Spalart Allmaras or SST k-omega models with a y+~1 in order to obtain more realistic values.
Also, check the dimensions of the mesh. Maybe your domain is too small and the wake is not fully captured (or mesh resolution is not enough in this region)
Jack80 is offline   Reply With Quote
Thread Tools
Trackbacks are On
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 17:16
Negative Pressure Drag Coefficient of main airfoil in Multi-Element rear wing Masoud.A1 FLUENT 4 April 8, 2015 23:17
Floworks and airfoil drag coefficient ap79 FloEFD, FloWorks & FloTHERM 4 November 14, 2014 10:45
Calculation of Drag Coefficient, Help Please teek22 CFX 1 April 26, 2012 18:41
