How to plot Mach contour in OF 4.0
Hello all,
I wanna to plot Mach contour in OF 4.0, using postProcess. I know the syntax is like postProcess -func "MachNo(U)", and then input this line in the terminal. However, the same error always occur, and I have no ideas what to do, please help me: Time = 8000 Reading fields: volVectorFields: U Executing functionObjects --> FOAM Warning : functionObject MachNo: Cannot find required field U End Thanks in advance. Best, Peter |
Hello all,
I am here to solve my own question again. First of all, for OpenFOAM 4.1 the warning message of MachNo is misleading. And this has been reported and revised by someone, please have a look at links below: https://bugs.openfoam.org/view.php?id=2352 https://github.com/OpenFOAM/OpenFOAM...a50f0a044ffd79 Next, for incompressible cases, plotting Mach Number contour is impossible, since OpenFOAM misses many thermodynamic parameters. As such, magnitude of velocity's contour is okay, considering the speed of sound is infinite when the medium is incompressible. I hope this post will help someone later. Best, Peter |
Thank you.This helped for OF5.0 case of mine. This was giving me error: Code:
postProcess -func MachNo Code:
Reading fields: Code:
sonicFoam -postProcess -func MachNo P.S. Although I have no idea how this error, as also mentioned in the development note here helps one to identify the source of error. Or maybe am missing to read something? |
