February 28, 2017, 09:57 |
Flow detachment point
Enrico Bezzi
Rep Power: 14 |
I'm simulating an axisymmetric flow of water coming from a central pipe then free flowing down a circular plate (see picture 'geometry'). I ran the same case with two values of flow rate (15 l/min and 70 l/min). The resulting fraction of water is shown in pictures 'water_15l' and 'water_70l'. Is the behaviour correct at the end of the plate? For 70 l/min water goes even upwards before detaching... Solver is interFoam, gravity is present (though you wouldn't tell from the results...) and surface tension sigma for water is set at 0.07 N/m. So is it correct that water detaches so late at the end of the plate or am I missing something in the model setup? Thank you |
Mass flow sink (source point) --Absolute pressure keeps dropping | njiang | CFX | 8 | April 14, 2017 08:17 |
Floating Point Error Segregated flow solver | willful | STAR-CCM+ | 2 | May 13, 2016 14:36 |
The adverse flow before the stagnation point of the blunt body | flyingseed | Main CFD Forum | 3 | April 4, 2013 04:11 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 04:59 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
