Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
flowRatePatch error: Region has no faces
Like Tree1Likes
  • 1 Post By Harrison Nobis
Old   March 1, 2017, 17:56
Default flowRatePatch error: Region has no faces
gea
gea is on a distinguished road
Hi:
I am working with OpenFoam 4 and I am using simpleFoam to simulate the flow in an open channel. I am using cyclic boundary conditions in the inlet and outlet patches.
I am trying to use flowRatePatch to calculate the discharge in the inlet or outlet patch, but I am getting this error:
surfaceRegion flowRatePatch: patch(outlet):
Region has no faces
I don't know if I am doing something wrong or it is because flowRatePatch don't work with cyclic patches.
Any help would be appreciated
gea is offline   Reply With Quote
Old   July 5, 2017, 03:49
Michael Pusterhofer
Mike_Pusti is on a distinguished road
Hi guys!
Is there any solution for this error message "Region has no faces"? I've got the error when i used volFlowRateSurface. It worked on similar cases, but how ever in my last case the flow calculation broke, no idea why...
Mike
Mike_Pusti is offline   Reply With Quote
Old   September 8, 2017, 23:44
Harrison Nobis
Harrison Nobis is on a distinguished road
I'm Having the same problem for a decomposed case when one processor doesn't contain the patch I'm trying to calculate flow rate from:
[0]
[0]
[0] --> FOAM FATAL ERROR:
[1]
[1]
[1] --> FOAM FATAL ERROR:
[1] [0] surfaceRegion flowRatePatch(name=left_BC): patch(left_BC):
Region has no faces
[0]
[0] From function void Foam::functionObjects::fieldValues::surfaceRegion: :initialise(const Foam::dictionary&)
[0] in file surfaceRegion flowRatePatch(name=left_BC): patch(left_BC):
Region has no faces
[1]
[1] From function void Foam::functionObjects::fieldValues::surfaceRegion: :initialise(const Foam::dictionary&)
[1] in file fieldValues/surfaceRegion/surfaceRegion.C at line 457.
[1]
FOAM parallel run exiting
[1]
[0]
[0]
Has anyone solved this problem?
Harrison Nobis is offline   Reply With Quote
Old   September 9, 2017, 03:39
Harrison Nobis
Hey just fixed my problem so I figured I would post my solution:
My issue was I had decomposed my mesh in such a way that the faces I was trying to measure the flow rate across where also the boundaries between processors.
My fix was to include: preservePatches (left_BC front) in my decomposeParDict
hope this helps someone with a similar problem.
AGhi likes this.
Old   September 4, 2018, 13:50
AGhi is on a distinguished road
Yes, it was. The right input at the right moment!
AGhi is offline   Reply With Quote
flowratepatch
Decomposing meshes Tobi OpenFOAM Pre-Processing 20 October 1, 2021 10:51
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 90 October 3, 2019 07:01
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
