reconstructPar error- Pointdisplacement
Please help me with this. I copied the error message below for a quick look. there is an error in the point displacement file under the folder processor 20. i had a look in the file and saw the pressure p0 (in processor20, p0 'nonuniform list<vector>' with a list of vector values in x y z direc) is not the same as in the previous processor(a single value ' nonuniform 0()'). When i change it to the same like other, i.e a single value and use the reconstructPar command, new error in processor23 (same error message as before for Proc20) .
Any idea how i could get rid of this error. :) thank you Error message: Time = 1 Reconstructing FV fields Reconstructing volScalarFields nuSgs rAU p Reconstructing volVectorFields U_0 U cellDisplacement Reconstructing surfaceScalarFields phi meshPhi Reconstructing point fields Reconstructing pointVectorFields pointDisplacement --> FOAM FATAL IO ERROR: size of field p0 (11) is not the same size as the patch (0) on patch airfoil of field pointDisplacement in file "/home/kb3g13/Yusik_pitching_32proc/processor23/1/pointDisplacement" file: /home/kb3g13/Yusik_pitching_32proc/processor23/1/pointDisplacement::boundaryField::airfoil from line 53545 to line 53567. From function genericPointPatchField<Type>::genericPointPatchFie ld(const pointPatch&, const Field<Type>&, const dictionary&) in file genericPointPatchField/genericPointPatchField.C at line 188. FOAM exiting |
