Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
reconstructPar error- Pointdisplacement
Old   March 2, 2017, 12:43
Default reconstructPar error- Pointdisplacement
kens
kensley12 is on a distinguished road
Please help me with this. I copied the error message below for a quick look. there is an error in the point displacement file under the folder processor 20. i had a look in the file and saw the pressure p0 (in processor20, p0 'nonuniform list<vector>' with a list of vector values in x y z direc) is not the same as in the previous processor(a single value ' nonuniform 0()'). When i change it to the same like other, i.e a single value and use the reconstructPar command, new error in processor23 (same error message as before for Proc20) .
Any idea how i could get rid of this error.
thank you
Error message:
Time = 1
Reconstructing FV fields
Reconstructing volScalarFields
nuSgs
rAU
p
Reconstructing volVectorFields
U_0
U
cellDisplacement
Reconstructing surfaceScalarFields
phi
meshPhi
Reconstructing point fields
Reconstructing pointVectorFields
pointDisplacement
--> FOAM FATAL IO ERROR:
size of field p0 (11) is not the same size as the patch (0)
on patch airfoil of field pointDisplacement in file "/home/kb3g13/Yusik_pitching_32proc/processor23/1/pointDisplacement"
file: /home/kb3g13/Yusik_pitching_32proc/processor23/1/pointDisplacement::boundaryField::airfoil from line 53545 to line 53567.
From function genericPointPatchField<Type>::genericPointPatchFie ld(const pointPatch&, const Field<Type>&, const dictionary&)
in file genericPointPatchField/genericPointPatchField.C at line 188.
FOAM exiting
kensley12 is offline   Reply With Quote
pointdisplacement, reconstructpar
reconstructPar --> fileName::stripInvalid() called for invalid fileName commandtouse adona058 OpenFOAM Bugs 34 December 8, 2022 21:27
reconstructPar does not work in interDyMFoam ageorg OpenFOAM Post-Processing 4 April 15, 2016 13:25
reconstructPar nor working Priya Somasundaran OpenFOAM Post-Processing 2 January 28, 2016 14:37
reconstructPar and a high number of snapshots fs82 OpenFOAM Programming & Development 2 April 18, 2012 04:37
Problem with reconstructPar fabianpk OpenFOAM 5 August 14, 2007 09:17
