January 6, 2012, 01:53 |
extraxt T_min out of log.sim
Stefan
Rep Power: 16 |
Hallo,
I pipe the openFoam output from the shell in a file called log.sim. To plot some date I use awk like: Code:
awk -f logs/foamLog.awk log.sim Code:
# Extraction of T_min fluid or solid /Min.max.T:/ { extract($0, "Min/max T:", val) file="./logs/T_min_" T_minCnt print Time " " val[1] > file T_minCnt++ } Min/max T:283.05995 283.15 |
January 7, 2012, 17:24 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
January 11, 2012, 05:23 |
Stefan
Rep Power: 16 |
Thanks for your help, but it do not work.
A possibitity is to read bouth variables and use only the second. Another is to read the last Variable in the line. Has anybody an Idea?? |
January 11, 2012, 05:56 |
Aurelien Thinat
Rep Power: 15 |
To extract values from output, with awk I use something like : "cat log.out |grep 'Tmin/max ='|awk '{print $i}' > Tmin.dat" replacing i by the number I want. In your case it should be something like 3 for Tmin and 4 for Tmax In another case, for extracting density rho max/min : 2.14 3.16 I used : "cat log.out |grep 'rho max/min' | cut -d' ' -f5|tr -d ',' > rhomin.dat" |
January 11, 2012, 06:22 |
Stefan
Rep Power: 16 |
Thanks for your idea! it runs with this :
/Min.max.T:/ { file="./logs/T_max_" T_maxCnt print Time " " $3 > file T_maxCnt++ } |
May 17, 2017, 01:33 |
Just for the records. I have been able to plot using bash scripting only, as I don't know awk...
cp -f postProcessing/domain2/minMax/0/field* minMax.dat sed -i -e '/p/d' minMax.dat sed -i -e '/U/d' minMax.dat gnuplot.exe //.exe --> I'm running openfoam with MySYS2 on windows set title "Max Temperatures" set autoscale xy set grid set ylabel "T [K]" set xlabel "Iterations" plot ' path to the file minMax.dat' using 1:8 w l title "T max" |
