vidyadhar
Rep Power: 10 ![]() |
Hello All,
I want to visualize the vortex structures in the flow through a pipe junction having square cross-section. I used the Lambda2<0 criterion. After execution of this command in terminal, for certain time steps, it is displaying : From function eigenValues(const tensor&) in file core/primitives/Tensor/tensor/tensor.cpp at line 164 complex eigenvalues detected for tensor: (0.2251204266 1.082743573e-10 -0.00015966764 1.082743573e-10 0.225120397 8.240372463e-07 -0.00015966764 8.240372463e-07 0.9004717292) Writing -Lambda2 1. Can anyone let me know what does this mean? When I tried to take the contours of Lambda2, in paraview, it is showing a range of values from negative to positive through zero. 2. Can anyone please explain why the range contains positive values too! By definition, Lambda2 should be negative so that it contains vortex cores? 3. So, which value of Lambda2 should I select, so as to contain the vortex cores? Negative or positive? Thanks in advance!!! |
#2 | |
Jianrui Zeng
Rep Power: 8 ![]() |
Rep Power: 15 ![]() |
Check out this wiki page -- it should answer your questions : https://en.wikipedia.org/wiki/Lambda2_method.
Caelan |
#4 | |
Arash
Rep Power: 9 ![]() |
#5 | |
xumengxin
Rep Power: 0 ![]() |
Display Modes | |
Positive or negative values of Lambda2 for vortex structure visualization? | vidyadhar | OpenFOAM Running, Solving & CFD | 3 | November 27, 2019 08:03 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
Stopping criterion for outer iteration loop | luftraudi | Main CFD Forum | 3 | February 22, 2017 08:59 |
Lambda2 in OpenFOAM utilities | cheng1988sjtu | OpenFOAM Post-Processing | 2 | April 30, 2013 10:57 |
Asymptotic stopping criterion is not working | rob50904 | STAR-CCM+ | 2 | January 28, 2013 08:25 |
