Usage of Lambda2 criterion??
Old   May 15, 2017, 08:17
Default Usage of Lambda2 criterion??
vidyadhar
vidyadhar is on a distinguished road
Hello All,
I want to visualize the vortex structures in the flow through a pipe junction having square cross-section.
I used the Lambda2<0 criterion.
After execution of this command in terminal, for certain time steps, it is displaying :
From function eigenValues(const tensor&)
in file core/primitives/Tensor/tensor/tensor.cpp at line 164
complex eigenvalues detected for tensor: (0.2251204266 1.082743573e-10 -0.00015966764 1.082743573e-10 0.225120397 8.240372463e-07 -0.00015966764 8.240372463e-07 0.9004717292)
Writing -Lambda2
1. Can anyone let me know what does this mean?
When I tried to take the contours of Lambda2, in paraview, it is showing a range of values from negative to positive through zero.
2. Can anyone please explain why the range contains positive values too!
By definition, Lambda2 should be negative so that it contains vortex cores?
3. So, which value of Lambda2 should I select, so as to contain the vortex cores? Negative or positive?
Thanks in advance!!!
vidyadhar is offline   Reply With Quote
Old   December 1, 2019, 23:14
Jianrui Zeng
calf.Z is on a distinguished road
Originally Posted by vidyadhar View Post
Hello All,
Writing -Lambda2
Any idea about these questions?
calf.Z is offline   Reply With Quote
Old   December 9, 2019, 14:19
clapointe is on a distinguished road
Check out this wiki page -- it should answer your questions : https://en.wikipedia.org/wiki/Lambda2_method.
Caelan
clapointe is offline   Reply With Quote
Old   July 6, 2020, 06:06
Arash
arashgmn is on a distinguished road
Hello All,
Writing -Lambda2
This might be useful for your third question.
arashgmn is offline   Reply With Quote
Positive or negative values of Lambda2 for vortex structure visualization? vidyadhar OpenFOAM Running, Solving & CFD 3 November 27, 2019 08:03
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Stopping criterion for outer iteration loop luftraudi Main CFD Forum 3 February 22, 2017 08:59
Lambda2 in OpenFOAM utilities cheng1988sjtu OpenFOAM Post-Processing 2 April 30, 2013 10:57
Asymptotic stopping criterion is not working rob50904 STAR-CCM+ 2 January 28, 2013 08:25
