May 26, 2017, 10:13 |
wallBoundedStreamLines problem
Federica Biano
Rep Power: 10 |
Hello everybody!
I tried to replicate the motorbike tutorial on a different geometry (ellipsoid) and with a different solver (interFoam). The aim of this work was to understand how the functions streamLines and wallBoundedStreamLines work. I run the simulation and it returned me the following error: Code:
Courant Number mean: 0.000233974 max: 2.20807 Interface Courant Number mean: 0 max: 0 deltaT = 0.000126984 Time = 0.001 PIMPLE: iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 0.00279774, Final residual = 2.18854e-11, No Iterations 2 Phase-1 volume fraction = 1 Min(alpha.water) = 0 Max(alpha.water) = 1.00045 Applying the previous iteration compression flux MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 1 Min(alpha.water) = 0 Max(alpha.water) = 1.00045 GAMG: Solving for p_rgh, Initial residual = 0.00110834, Final residual = 9.75963e-07, No Iterations 11 time step continuity errors : sum local = 3.40684e-13, global = 2.92774e-15, cumulative = -4.4328e-12 GAMG: Solving for p_rgh, Initial residual = 0.000110899, Final residual = 9.6783e-08, No Iterations 25 time step continuity errors : sum local = 3.37619e-14, global = 3.26162e-16, cumulative = -4.43248e-12 GAMG: Solving for p_rgh, Initial residual = 3.25483e-05, Final residual = 4.75125e-08, No Iterations 30 time step continuity errors : sum local = 1.65688e-14, global = -2.3214e-16, cumulative = -4.43271e-12 smoothSolver: Solving for omega, Initial residual = 1.15728e-05, Final residual = 5.80695e-12, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.00024992, Final residual = 9.11317e-11, No Iterations 1 ExecutionTime = 448.31 s ClockTime = 449 s streamLine streamLines write: seeded 20 particles Tracks:20 Total samples:30974 Writing data to "/home/idr/Shared/Biano/ellissoide12m/processor0/../postProcessing/sets/streamLines/0.001" nearWallFields near write: Sampling fields to 0.001 Writing sampled fields to 0.001 wallBoundedStreamLine : seeded 1995 particles. [10] #0 Foam::error::printStack(Foam::Ostream&)[0] #0 Foam::error::printStack(Foam::Ostream&)[2] [9] #0 Foam::error::printStack(Foam::Ostream&)#0 Foam::error::printStack(Foam::Ostream&)[8] #0 Foam::error::printStack(Foam::Ostream&)[4] #0 Foam::error::printStack(Foam::Ostream&)[6] [1] #0 Foam::error::printStack(Foam::Ostream&)#0 Foam::error::printStack(Foam::Ostream&)[7] #0 Foam::error::printStack(Foam::Ostream&)[11] #0 Foam::error::printStack(Foam::Ostream&) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [0] #1 Foam::sigFpe::sigHandler(int) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [8] #1 Foam::sigFpe::sigHandler(int) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [4] #1 Foam::sigFpe::sigHandler(int) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [6] #1 Foam::sigFpe::sigHandler(int) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [2] #1 Foam::sigFpe::sigHandler(int) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [9] #1 Foam::sigFpe::sigHandler(int) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [7] #1 Foam::sigFpe::sigHandler(int) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [11] #1 Foam::sigFpe::sigHandler(int) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [10] #1 Foam::sigFpe::sigHandler(int) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigHandler(int) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [9] #2 ? in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [1] #2 ? in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [11] #2 ? in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [7] #2 ? in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [2] #2 ? in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [10] #2 ? in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [0] #2 ? in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [8] #2 ? in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [4] #2 ? in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [6] #2 ? in "/lib64/libc.so.6" [9] #3 Foam::wallBoundedStreamLineParticle::sample(Foam::wallBoundedStreamLineParticle::trackingData&) in "/lib64/libc.so.6" [1] #3 Foam::wallBoundedStreamLineParticle::sample(Foam::wallBoundedStreamLineParticle::trackingData&) in "/lib64/libc.so.6" [11] #3 Foam::wallBoundedStreamLineParticle::sample(Foam::wallBoundedStreamLineParticle::trackingData&) in "/lib64/libc.so.6" [6] #3 Foam::wallBoundedStreamLineParticle::sample(Foam::wallBoundedStreamLineParticle::trackingData&) in "/lib64/libc.so.6" [2] #3 Foam::wallBoundedStreamLineParticle::sample(Foam::wallBoundedStreamLineParticle::trackingData&) in "/lib64/libc.so.6" [0] #3 Foam::wallBoundedStreamLineParticle::sample(Foam::wallBoundedStreamLineParticle::trackingData&) in "/lib64/libc.so.6" [8] #3 Foam::wallBoundedStreamLineParticle::sample(Foam::wallBoundedStreamLineParticle::trackingData&) in "/lib64/libc.so.6" [4] #3 Foam::wallBoundedStreamLineParticle::sample(Foam::wallBoundedStreamLineParticle::trackingData&) in "/lib64/libc.so.6" [7] #3 Foam::wallBoundedStreamLineParticle::sample(Foam::wallBoundedStreamLineParticle::trackingData&) in "/lib64/libc.so.6" [10] #3 Foam::wallBoundedStreamLineParticle::sample(Foam::wallBoundedStreamLineParticle::trackingData&) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so" [11] #4 Foam::wallBoundedStreamLineParticle::move(Foam::wallBoundedStreamLineParticle::trackingData&, double) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so" [9] #4 Foam::wallBoundedStreamLineParticle::move(Foam::wallBoundedStreamLineParticle::trackingData&, double) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so" [1] #4 Foam::wallBoundedStreamLineParticle::move(Foam::wallBoundedStreamLineParticle::trackingData&, double) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so" [7] #4 Foam::wallBoundedStreamLineParticle::move(Foam::wallBoundedStreamLineParticle::trackingData&, double) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so" [6] #4 Foam::wallBoundedStreamLineParticle::move(Foam::wallBoundedStreamLineParticle::trackingData&, double) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so" [2] #4 Foam::wallBoundedStreamLineParticle::move(Foam::wallBoundedStreamLineParticle::trackingData&, double) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so" [0] #4 Foam::wallBoundedStreamLineParticle::move(Foam::wallBoundedStreamLineParticle::trackingData&, double) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so" [8] #4 Foam::wallBoundedStreamLineParticle::move(Foam::wallBoundedStreamLineParticle::trackingData&, double) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so" [4] #4 Foam::wallBoundedStreamLineParticle::move(Foam::wallBoundedStreamLineParticle::trackingData&, double) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so" [10] #4 Foam::wallBoundedStreamLineParticle::move(Foam::wallBoundedStreamLineParticle::trackingData&, double) in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so" [11] #5 void [.........................] [ce-lnx-0953:25568] [ 4] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam29wallBoundedStreamLineParticle4moveERNS0_12trackingDataEd+0x100)[0x7f62353393b0] [ce-lnx-0953:25568] [ 5] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam5CloudINS_29wallBoundedStreamLineParticleEE4moveINS1_12trackingDataEEEvRT_d+0x86e)[0x7f62353373de] [ce-lnx-0953:25568] [ 6] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam15functionObjects21wallBoundedStreamLine5trackEv+0xdbf)[0x7f623533152f] [ce-lnx-0953:25568] [ 7] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam15functionObjects21wallBoundedStreamLine5writeEv+0x57)[0x7f62353332a7] [ce-lnx-0953:25568] [ 8] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam15functionObjects11timeControl5writeEv+0x2e)[0x7f625615bb6e] [ce-lnx-0953:25568] [ 9] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam18functionObjectList7executeEv+0x63)[0x7f6256151ad3] [ce-lnx-0953:25568] [10] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam4Time3runEv+0x8f)[0x7f625615f8af] [ce-lnx-0953:25568] [11] interFoam[0x4927a6] [ce-lnx-0953:25568] [12] /lib64/libc.so.6(__libc_start_main+0xfd)[0x31efc1ed1d] [ce-lnx-0953:25568] [13] interFoam[0x434431] [ce-lnx-0953:25568] *** End of error message *** in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/interFoam" [ce-lnx-0953:25574] *** Process received signal *** [ce-lnx-0953:25574] Signal: Floating point exception (8) [ce-lnx-0953:25574] Signal code: (-6) [ce-lnx-0953:25574] Failing at address: 0x1f6000063e6 [ce-lnx-0953:25574] [ 0] /lib64/libc.so.6[0x31efc32660] [ce-lnx-0953:25574] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x31efc325e5] [ce-lnx-0953:25574] [ 2] /lib64/libc.so.6[0x31efc32660] [ce-lnx-0953:25574] [ 3] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam29wallBoundedStreamLineParticle6sampleERNS0_12trackingDataE+0x6e)[0x7f83105b023e] [ce-lnx-0953:25574] [ 4] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam29wallBoundedStreamLineParticle4moveERNS0_12trackingDataEd+0x100)[0x7f83105b03b0] [ce-lnx-0953:25574] [ 5] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam5CloudINS_29wallBoundedStreamLineParticleEE4moveINS1_12trackingDataEEEvRT_d+0x86e)[0x7f83105ae3de] [ce-lnx-0953:25574] [ 6] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam15functionObjects21wallBoundedStreamLine5trackEv+0xdbf)[0x7f83105a852f] [ce-lnx-0953:25574] [ 7] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam15functionObjects21wallBoundedStreamLine5writeEv+0x57)[0x7f83105aa2a7] [ce-lnx-0953:25574] [ 8] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam15functionObjects11timeControl5writeEv+0x2e)[0x7f83315a9b6e] [ce-lnx-0953:25574] [ 9] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam18functionObjectList7executeEv+0x63)[0x7f833159fad3] [ce-lnx-0953:25574] [10] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam4Time3runEv+0x8f)[0x7f83315ad8af] [ce-lnx-0953:25574] [11] interFoam[0x4927a6] [ce-lnx-0953:25574] [12] /lib64/libc.so.6(__libc_start_main+0xfd)[0x31efc1ed1d] [ce-lnx-0953:25574] [13] interFoam[0x434431] [ce-lnx-0953:25574] *** End of error message *** in "/apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/interFoam" [ce-lnx-0953:25570] *** Process received signal *** [ce-lnx-0953:25570] Signal: Floating point exception (8) [ce-lnx-0953:25570] Signal code: (-6) [ce-lnx-0953:25570] Failing at address: 0x1f6000063e2 [ce-lnx-0953:25570] [ 0] /lib64/libc.so.6[0x31efc32660] [ce-lnx-0953:25570] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x31efc325e5] [ce-lnx-0953:25570] [ 2] /lib64/libc.so.6[0x31efc32660] [ce-lnx-0953:25570] [ 3] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam29wallBoundedStreamLineParticle6sampleERNS0_12trackingDataE+0x6e)[0x7f5d8a72723e] [ce-lnx-0953:25570] [ 4] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam29wallBoundedStreamLineParticle4moveERNS0_12trackingDataEd+0x100)[0x7f5d8a7273b0] [ce-lnx-0953:25570] [ 5] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam5CloudINS_29wallBoundedStreamLineParticleEE4moveINS1_12trackingDataEEEvRT_d+0x86e)[0x7f5d8a7253de] [ce-lnx-0953:25570] [ 6] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam15functionObjects21wallBoundedStreamLine5trackEv+0xdbf)[0x7f5d8a71f52f] [ce-lnx-0953:25570] [ 7] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam15functionObjects21wallBoundedStreamLine5writeEv+0x57)[0x7f5d8a7212a7] [ce-lnx-0953:25570] [ 8] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam15functionObjects11timeControl5writeEv+0x2e)[0x7f5dab8e2b6e] [ce-lnx-0953:25570] [ 9] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam18functionObjectList7executeEv+0x63)[0x7f5dab8d8ad3] [ce-lnx-0953:25570] [10] /apps/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam4Time3runEv+0x8f)[0x7f5dab8e68af] [ce-lnx-0953:25570] [11] interFoam[0x4927a6] [ce-lnx-0953:25570] [12] /lib64/libc.so.6(__libc_start_main+0xfd)[0x31efc1ed1d] [ce-lnx-0953:25570] [13] interFoam[0x434431] [ce-lnx-0953:25570] *** End of error message *** ?-------------------------------------------------------------------------- mpirun noticed that process rank 7 with PID 25573 on node ce-lnx-0953 exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- I would really appreciate your help. (I'm using OF4.1) Federica |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
