June 5, 2017, 15:32 |
Visualization on ParaView
Guilherme
Rep Power: 10 |
I am having a post processing question about my simulation, I would like help. I did a simulation on OpenFOAM, external flow in a cylinder, however, I can not visualize the simulation correctly, I would like to know the steps that I must take to be able to see the flow at the top. I even modified the scale of the legend, and it was not even possible to visualize the Vortex of Karman. 3D.jpg |
June 5, 2017, 16:33 |
Rep Power: 13 |
Not sure what you mean. I can see the von Karman Vortex on your xy-plane. You want to look on the xz-plane? To see what exactly?
Edit: Maybe you want a slice to look on the vortex from xz-plane. Use the Slice function (third icon right from calculator.) then adjust the normal vector from 1 0 0 to what you need. e.g. 0 0 1 etc. |
June 5, 2017, 17:11 |
Guilherme
Rep Power: 10 |
I want do see my simulation same this:
https://www.youtube.com/watch?v=k4rQ_nj2UZs I dont know how to do. |
June 6, 2017, 04:33 |
Rep Power: 13 |
You need Contour plot for this. Use Contour button and choose as variable pressure or velocity or similiar. Also define the value you want the contours of. e.g. 1 m/s for velocity contours. It will give you the contours of this value in the whole domain. If you dont see anything the chossen value is not present (at current time step)
June 6, 2017, 07:36 |
Guilherme
Rep Power: 10 |
I got it, thanks.
I am new with post processing in ParaView. I tried to make the IsoSurface of the speed (U) and the vorticity function (whose I inserted into my ControlDict), but both options are not selectable in Countour, why? I can select 'p', 'omega', 'nut', 'yPlus' ... 'Co'. |
June 6, 2017, 07:46 |
Rep Power: 13 |
Actually i don't know the reason. I would be interested to know too..
June 6, 2017, 10:50 |
Joshua
Rep Power: 9 |
gu1,
To do a contour of U, you need to make it a scaler and not a vector. Use the calculator filter and use the equation "mag(U)". After that you should be able to select velocity for your contour. Joshua |
June 6, 2017, 10:59 |
Guilherme
Rep Power: 10 |
Thanks, I will try.
Can I do same for vorticity? |
June 6, 2017, 11:05 |
#9 |
Yes you can, in fact you can also define your own variables. !!!
June 6, 2017, 11:12 |
#10 |
Joachim Herb
Rep Power: 21 |
Ah, too late:
I think you can only use scalar values for IsoSurface. I think you can create a new scalar field with the magnitude of U and use this as input for the IsoSurface. |
June 6, 2017, 11:16 |
#11 |
Guilherme
Rep Power: 10 |
Ok, I will try. Thank you very much for your attention.
I have a simple question, already taking advantage of the topic and being of the same subject ... is it necessary that I convert to VTK (foamToVTK) correct? I did, but by '' automatic mode '' due to other forum topics. |
June 6, 2017, 11:30 |
#12 |
Guilherme
Rep Power: 10 |
I do not know exactly where to make this modification, could you help me?
June 6, 2017, 11:37 |
#13 |
Joshua
Rep Power: 9 |
openfoam, paraview, post processing |
[General] Paraview Visualization | Raza Javed | ParaView | 0 | April 10, 2019 06:54 |
3d visualization using paraview | ashishsiwalkar | OpenFOAM Programming & Development | 0 | September 8, 2016 02:14 |
Problems with visualization (bundled ParaView 3.8) in Ubuntu 10.04 | eiffleduarte | OpenFOAM | 1 | July 13, 2010 17:59 |
[OpenFOAM] Visualization with ParaView (in general) | sega | ParaView | 7 | February 1, 2010 02:24 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
