Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculate Heat Flux in a Patch
Old   April 27, 2021, 05:40
Cool Calculate Heat Flux in a Patch
grubi is on a distinguished road
Hello community,
I simulated the flow inside a nozzle using the rhoCentralFoam solver and I want to calculate the heat flux along the nozzle wall. However, this is a special case as I replaced the "wall" with an inlet to reproduce something similar to a nozzle with sweat cooling.
The thing is the wallHeatFlux only gives me the heat fluxes in boundaries defined as "wall" and I do not have much experience modifying the code.
Anyone has an idea of how can I determine the heat flux along a patch?
Thank you in advance
grubi is offline   Reply With Quote
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 6 January 12, 2021 05:55
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 04:48
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
how to Calculate heat flux??? sandip Main CFD Forum 0 December 4, 2009 04:58
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
