Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Computing streamlines for 2D pipe from command line
Old   June 24, 2017, 10:25
Default Computing streamlines for 2D pipe from command line
bomo is on a distinguished road
I have simulated a 2D pipe and would like to compute automatically form the command line (not paraview) a couple of streamlines. Unfortunately, I'm new to OpenFoam and new to its post-processing functionalities.
While searching I stumbled upon this and the function example therein. However, I neither know how to execute such a function nor how to adapt it to my needs.
I computed the 2D pipe using simpleFoam and obtained U and p fields. I would like to compute the streamlines from beginning of the pipe till its end (inflow till outflow). The part about "uniformCoeffs" in the example function I guess I understand and can modify to my needs. But how do I have to change e.g. "lifeTime", "trackLength" and "nSubCycle" ? And how to run this function?
Thanks a lot for your help in advance.
bomo is offline   Reply With Quote
streamlines
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 22:14
Double Walled Pipe Boundary dahvqaz FLUENT 2 December 5, 2012 10:14
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
computing streamlines yfyap Main CFD Forum 3 July 31, 2001 23:07
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
