September 18, 2015, 13:14 |
Evenly distributed vector plot
SM
Rep Power: 15 |
I have a structure mesh on which I want to plot vectors.
I use slice and glyph but I get vectors in random fashion. What I want is something like in the picture I have read about Resample With DataSet but in this case it will be a tedious task. Is there a easy way out? |
September 18, 2015, 14:11 |
By default Glyph filter uses Random mode for selecting points. You can: - increase number of points (to the total number of cells in you mesh) - turn off masking, so Glyph uses all mesh points Screenshot with settings for Paraview 4.3.1 is attached to the message. For other versions it should be similar. |
September 19, 2015, 12:53 |
SM
Rep Power: 15 |
Many thanks for answer with the image!
It seems that the option Code:
mask stride I downloaded the paraview version 4.3.1. But I can not load the velocity field maybe as a coded velocity profile in 0/U is used instead of numeric values. It works fine Paraview 4.1.0 bundled with OpenFOAM. Code:
ERROR: In /home/kitware/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6467 vtkOpenFOAMReaderPrivate (0x3900fd0): Error reading line 30 of x/y/z/0/U: Unsupported directive { Manually renaming 0 is last option I prefer. Thanks & regards |
September 20, 2015, 06:25 |
Well, here is screenshot from 4.1.0. You can either
June 30, 2017, 06:16 |
about random mode
Yuanwei Cao
Rep Power: 8 |
Display Modes | |
[OpenFOAM] Evenly distributed arrows using glyph in ParaView | kriz | ParaView | 4 | January 26, 2016 04:23 |
[ICEM] nodes in sweep direction not evenly distributed | fmarlow | ANSYS Meshing & Geometry | 1 | December 19, 2012 04:32 |
HP MPI warning...Distributed parallel processing | Peter | CFX | 10 | May 14, 2011 07:17 |
Firewall settings bproc distributed file syntax | mike_jaworski | OpenFOAM | 2 | January 14, 2008 11:46 |
distributed mpich problem | Trevor | CFX | 15 | January 9, 2007 18:08 |
