May 7, 2018, 10:15 |
problem sampling a plane in parallel
Syavash Asgari
Rep Power: 18 |
Dear Foamers,
I have a problem when sampling a plane in parallel mode. In serial mode, everything is fine with sampling data on a plane during run-time. The 2-D sampled planes are properly captured and the flow pattern is reasonable. However, when I decompose my case and run the job in parallel mode, I get some EXTRA regions outside of the pre-defined sampling space. For instance, if I define a 2-D sampling plane normal to Z-direction, in serial mode it looks fine but in parallel mode some other regions (in different Z-coordinates) are captured along. I guess that this is a problem with data distribution among the different processes, as I could virtually resolve it by decomposing in a direction normal to the sampling plane (Here in Z-direction). However, this cannot be a real solution as I cannot afford to decompose my other grids in Z-direction. I wonder if some people have run into this problem before and already have found the solution. Regards, Syavash P.S. I use OF 2.3.1 |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Problem with parallel computation (case inviscid onera M6) | Combas | SU2 | 11 | January 30, 2014 01:20 |
problem in the CFX12.1 parallel computation | BalanceChen | ANSYS | 2 | July 7, 2011 10:26 |
Total mass flow/flux through a plane problem | nwalters | FLUENT | 1 | December 18, 2010 12:23 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 15:41 |
