September 11, 2017, 15:21 |
PDF format image
Rep Power: 10 |
Hello to all,
Is it possible to obtain vectorial image format in paraview? What are the procedure you usually do to obation high resolution image? Thanks for help |
September 12, 2017, 10:11 |
#2 | |
Rep Power: 11 |
You can save vector EPS/PDF files with the "Export Scene" function under the "File" drop down list. But normally I use the "Save Screenshot" function both manually in Paraview and when running pvpython scripts. With this function you can save custom resolution PNG/JPEG files and tune the quality and resolution of the image. Cheers |
September 23, 2017, 11:27 |
#3 | |
Rep Power: 10 |
*.json *.pov *.vrml *.webgl *.x3d *.x3db Maybe could EPS/PDF options depend on the version? Regards |
September 25, 2017, 12:46 |
#4 | |
Rep Power: 11 |
Have checked the versions that i normally run (4.3.1 and 5.4.1), and in both of these versions is the following formats available: *.eps *.ps *.svg *.pov *.vrml *.webgl *.x3d *.x3db When testing to export different types of data, i noticed that the available formats in this list change, so could your problem be more connected to the data? Cheers |
[Commercial meshers] About the Commercial and Closed Source Meshers discussed here | wyldckat | OpenFOAM Meshing & Mesh Conversion | 3 | July 22, 2020 22:09 |
[ANSYS Meshing] How to generate mesh from segmented image | paoching | ANSYS Meshing & Geometry | 0 | March 21, 2019 13:37 |
How to successfully export jpeg image with User defined Windows Size in Batch mode | potofus | EnSight | 2 | April 26, 2016 03:25 |
programming new format writer for surface sampling | Kossivi | OpenFOAM Programming & Development | 7 | October 24, 2015 16:47 |
NASTRAN Data format | Srinivasan Arunajatesan | Main CFD Forum | 1 | January 2, 2014 06:20 |
