September 22, 2017, 09:24 |
Standard utilities, noob question,
Marius Lang
Rep Power: 8 |
Hello
How do you run Standard utilities in openFoam? I have created a flow over a cylinder and I want to find its separation point, this can be found when the gradient of the boundary layer is zero, and I therefore want to compute wallGradU, but how do you run wallGradU, I tried to type icoFoam -postProcess -func WallGradU, but got error message (see picture). Do you need to implement it as a function in controlDict? I also tried this but got a error message as well |
September 22, 2017, 09:46 |
Rep Power: 10 |
As you can see on the output (invalid arguments) icofoam has no option postprocess.
postprocess is an own openfoam utility. See the tutorial https://cfd.direct/openfoam/user-gui...#x5-130002.1.4 and https://cfd.direct/openfoam/user-gui...31-2400006.2.3 |
September 22, 2017, 09:54 |
Rep Power: 10 |
and if I type "wallGradU" into the console (it was an openFoam utility)
then the following output is printed: wallGradU has been superseded by the postProcess utility: postProcess -func 'grad(U)' |
September 22, 2017, 14:42 |
Marius Lang
Rep Power: 8 |
Thank you for your help robob. The postProcess -func 'grad(U)' it worked for time step 0 but for timestep 1,2,3 and so forth, it coulndt find required field U.
The command postProcess -func 'components(U)' worked fine though. How do you create field U? Is this done in the fvSolution with a gradscheme in fvSchemes? Last edited by Ursmooth; September 22, 2017 at 18:24. |
September 23, 2017, 02:05 |
Rep Power: 10 |
Normally U is writtten to all timesteps. There is something wrong with your solver. What commands do you execute for your simulation?
September 23, 2017, 02:12 |
Shrirang
Rep Power: 9 |
There is an option in controlDict about writing files every time step, you can check that for your case.
Shrirang |
September 23, 2017, 03:42 |
Marius Lang
Rep Power: 8 |
Just icoFoam, but I found this thread How to get grad(p) in OpenFOAM and it seems to be a bug in openfoam 4.1. The same version I am using.
September 23, 2017, 03:46 |
Rep Power: 10 |
Looks like an bug indeed, thanks for the notice. Maybe you should try with OpenFOAM 5?
September 23, 2017, 04:49 |
#9 |
Marius Lang
Rep Power: 8 |
Yes I will try that, Thanks again for your help!
question about uds | tanven | FLUENT | 2 | July 5, 2015 11:22 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Question about calculating standard deviation | Alicelin | OpenFOAM Running, Solving & CFD | 0 | January 19, 2010 23:27 |
Question about Table applicaiton. | universez | OpenFOAM Running, Solving & CFD | 0 | January 12, 2010 20:31 |
A Simple Question | Thomas P. Abraham | Main CFD Forum | 3 | September 6, 1999 18:19 |
