Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Drag coefficients in OpenFOAM
Old   September 28, 2017, 09:44
Default Drag coefficients in OpenFOAM
Friendly is on a distinguished road
Hello everyone,
currently I am struggling with the calculation of drag for an Ahmed Body.
My first Question is how does OpenFOAM calculate the drag? I assume it integrates the difference in pressure and the shearing stress on the surface and adds them both, is that correct? I am using the library libforces.so:
  forceCn
        type            forceCoeffs;
        libs ( "libforces.so" );
        writeControl   timeStep;
        writeInterval  1;
        patches         ( "Nose");
        rho             rhoInf;
    pRef        0;
        log             true;
        rhoInf          1.2;
        liftDir         (0 0 1);
        dragDir         (-1 0 0);
        CofR            (0 0 0);
        pitchAxis       (0 1 0);
        magUInf         40;
        lRef            1;
        Aref            0.112;
The drag coefficient at the nose is supposed to be 0.02 http://user.engineering.uiowa.edu/~m...FDEFDahmed.pdf (what seems very low considering the geometry).
My calculations deliver 0.3. Therefore my absolute drag coefficient of the Ahmed Body ist about two times higher than in the paper. The drag coefficients at the back and rear slop are almost the same as in the paper, it is just the drag coefficient at the nose of the body. And why is the drag coefficient at the rear slop and the back positive anyway? Isnt it supposed to be negative, because the pressure difference is negative?
Thanks for any advice, I hope you can help!
Greetings,
Friendly
Friendly is offline   Reply With Quote
drag
drag and lift coefficients in axisymmetric and 3D simulations! CFD-Lover OpenFOAM Running, Solving & CFD 0 July 1, 2017 17:33
Drag Components in OpenFoam adr OpenFOAM Post-Processing 4 March 30, 2017 07:35
Role of Reference area for calculating drag and lift coefficients. shashanktiwari619 ANSYS 0 February 8, 2017 06:18
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
