Runtime probe function with large number of points |
October 11, 2017, 18:08 |
Regis
Rep Power: 14 |
I'm using an object function in my controlDict to save the velocity of several points at every fixed number of time step intervals. My use is analogous to the one present in the following tutorial
$FOAM_TUTORIALS/incompressible/pimpleFoam/RAS/TJunction I have tried doing this defining probe lines using 'sets', but I end up with way too many files for post processing. Using 'probes' I will have a single file at the end. Any ideas or hints about why this is happening and/or possible workarounds? -Regis PS:I should mention that I'm using a relatively old version, 2.3.1. I have too many custom solvers for this version and can't afford the time to port them to newer versions, so I'd appreciate solutions that are available in such old version. |
probes, runtime postprocessing |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
