Home > Forums > OpenFOAM Post-Processing
Volume Calculation
Like Tree1Likes
  • 1 Post By Dipsomaniac
Old   October 23, 2017, 16:43
Arrow Volume Calculation
FlyBob91's Avatar
FlyBob91 is on a distinguished road
Hello to all,
I need to calculate volumes of two mesh and i can't use the usual command checkMesh because it gives to me the same results because it doesn't show enough decimal digits.
Here my case: in the first pic there is my original geometry with straight walls, in the second there is the modified geometry with an irregular wall. The volume change in the second case is very little because inwards and outwards displacements compensate themselves but not totally. Now, how can i know the little volume variation? The irregular wall is a distinct patch, if i show it and not the others can i calculate its volume?
Thanks for help
FlyBob91 is offline   Reply With Quote
Old   October 23, 2017, 17:47
Brian Willis
Dipsomaniac is on a distinguished road
Hi Flybob
You can try the writeCellVolumes post process function which creates a volScalarField of the volume for each cell, and then integrate scalar field using another post process function.
Regards,
Brian
FlyBob91 likes this.
Dipsomaniac is offline   Reply With Quote
Old   October 23, 2017, 18:07
FlyBob91's Avatar
Originally Posted by Dipsomaniac View Post
Hi Flybob
Regards,
Brian
Hi Dipsomaniac, it seems the command you suggested me is what i need.
Many many thanks
Thread Tools
Trackbacks are On
multiphaseEulerFoam high Courant number Frenk_T OpenFOAM 5 November 24, 2016 04:23
Wrong Calculation of Cell Volume olli191 ParaView 1 August 3, 2016 04:09
error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Native Meshers: blockMesh 2 March 14, 2012 10:56
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
