Total pressure compressible flow
hello all,
I am working on scramjet inlet i want total pressure recovery so when we calculated total pressure results from fluent and OpenFoam are very different. rest pressure(static),density,MachNO.velocity matches well. fluent uses formula Pt = Po *(1+ (kappa-1)*M^2 /2)^(kappa/kappa-1) for openFoam i used postProcess utility totalPressureCompressible results are not matching up can u guys help |
That is because OpenFOAM uses:
which should equal the Fluent value only in isentropic flow conditions. You can find some explanation on the funtionObjects in the cpp source guide I would suggest to use a ParaView calculator to use the same formulation as Fluent. Regards, Tom |
