wallHeatFlux with laminar flow
Hello everyone. I try to use wallHeatFlux utility on OpenFOAM 5 for laminar case. However, I get this error even I have turbulenceProperties file in the constant folder:
Unable to find compressible turbulence model in the database Thanks. |
The message is telling you that the postProcess utility has not information about the turbulence model use in simulation. You can run the postProcess with the solver: <your_solver> -postProcess -func wallHeatFlux -region <region_name> |
How to run wallHeatFlux please?
Hallo Foamers,
I am a little confused about functionObjects. I wrote in controlDict Code:
functions Code:
chtMultiRegionSimpleFoam -postProcess Code:
chtMultiRegionSimpleFoam -postProcess -func wallHeatFlux -region heater Code:
Cannot find functionObjects file wallHeatFlux Code:
wallHeatFlux -region heater Why the former two command do not work please? Thank you very much in advance! Best regards, sitajeje |
chtMultiRegionSimpleFoam does not offer wallHeatFlux function. you need to use wallHeatFlux option of chtMultiRegionFoam. Quote:
