December 8, 2017, 13:27 |
Wallshear stress sngrad() implementation
Mathia
Rep Power: 8 |
Hello, I am fairly new in the world of OpenFoam and CFD. I am trying to calculate wallshear stress on a cylinder surface (laminar flow) and this thread: Compute shear stress interFoam told me to use the formula: "wallShear = nu * rho * mesh.boundaryField()[patchID].snGrad()", since now I am only using the standard openFoam utility wallshear stress and it does not give adequate results.
So my question is how do you implement/run "mesh.boundaryField()[patchID].snGrad()" ?? Is this something you have to add in the wallshearstress source code? I am a bit confused if you are supposed to add it in a code or run it somehow. Not really programmed in C before, only matlab. Help is much appreciated! |
December 9, 2017, 01:11 |
Uwe Pilz
Rep Power: 15 |
An easy and understandable way is using the result in velocity and pressure radial of the cylinder. You may use the sample tool and put in the sampleDict all the radial lines you need.
From this output it is easy to calculate the wall shear stress.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
December 9, 2017, 13:43 |
Mathia
Rep Power: 8 |
Thank you for your reply! I am not really sure how this is supposed to be done? As wall shear stress involves the derivative, and my cylinder has 300 points which means I have to make 300 lines in my sample dict, which seems quite tedious. My end goal is to get the tangential wall shear stress
December 9, 2017, 14:20 |
Uwe Pilz
Rep Power: 15 |
Would be not a problem for me. I would write a small script which generates them.
[ANSYS Meshing] Error in Workbench "Unable to attach to geometry file" | Jeremie84 | ANSYS Meshing & Geometry | 70 | October 25, 2017 16:03 |
Implementation into the reynolds stress equation | aki_yafuji | OpenFOAM | 0 | April 15, 2011 22:51 |
Wallshear stress simplefoam | rengu | OpenFOAM Running, Solving & CFD | 0 | December 14, 2007 05:21 |
shear stress scalar definitions? | Novak Elliott | CFX | 0 | April 6, 2003 01:45 |
Implementation of Stress and Gentra | Javier Larrondo | Phoenics | 5 | March 2, 2001 12:34 |
