sample line along a curved of a boundary patch |
November 15, 2017, 09:07 |
Luca
Rep Power: 15 |
Dear All,
suppose I have a pipe and I want to sample values of a variable along the wall. How can I accomplish it at every face centre with the sampling utility of OF (in my case OF 5)? I know it is possible to specify a "cloud" of points and sample at those locations. Is it a better way to do it with OF (instead of using paraview?)?. Thank you in advance. Luca |
December 28, 2017, 16:32 |
Canakkale Dardanelspor
Rep Power: 13 |
To myself (and alike), two clarifications in your question might be needed: 1. When you state "along the wall", do you mean boundary or internal values of some flow field? 2. When you state "sampling", do you actually mean "probing", as "cloud" indicates probing a simulation 'on-the-fly', yet sampling is usually termed for after-the-termination of a simulation? |
December 28, 2017, 16:52 |
Luca
Rep Power: 15 |
first of all thank you for your answer. Now, back to your (correct) questions regarding my post: 1. I mean along a boundary wall 2. Sampling as post-processing along the boundary wall for the face values Best Regards, Luca |
December 28, 2017, 17:32 |
Rep Power: 13 |
May I also ask which version of OpenFOAM you are using? There was a paradigm change in sampling and probing fields from OF version 3 towards 4.
December 28, 2017, 17:45 |
Luca
Rep Power: 15 |
I am using OF 4.x or OF 5.x. Thank you again for your time. Best Regards, Luca |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
