[OpenFOAM] How to plot wall shear stress on T3A tutorial in paraview? |
January 24, 2018, 00:38 |
ESI
Rep Power: 8 |
The wall shear stress had been calculated in the T3A tutorial in OpenFoam?
Can someone tell me the exact steps in paraview? Any advice will be grateful. Thanks |
February 19, 2018, 18:01 |
D L
Rep Power: 13 |
Assuming you've loaded the results properly
1. Create a function to calculate Cf. Calculator. Cf = mag(wallShearStress)/(0.5*5.4^2) 2. PlotOverLine point1 0.040219, 0.00075, 0 point2 3.04, 0.00075, 0 This should open a line graph. Deselect the variables except for your Cf variable Also, if you have gnuplot installed, there's a script inside the validation directory that should enable you to plot via gnuplot |
[General] How to plot wall shear stress on airfoil in paraview? | ht2017 | ParaView | 0 | January 24, 2018 00:35 |
How can I plot area averaged wall shear stress variation with time over a surface? | Gourabc | FLUENT | 0 | January 31, 2017 23:56 |
Wall Shear Stress Sampling Probes | Mahe88 | OpenFOAM Post-Processing | 0 | December 14, 2016 10:09 |
Drift-flux model and wall shear stress | laoji | FLUENT | 0 | July 8, 2014 22:42 |
LES: mean wall shear stress | Francois | FLUENT | 0 | July 7, 2005 11:15 |
