Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
mass flow average Temperature - of5 - chtmultiregionFoam
Like Tree1Likes
  • 1 Post By tomf
Old   February 12, 2018, 05:40
Default mass flow average Temperature - of5 - chtmultiregionFoam
sprinter is on a distinguished road
Hello Foamers,
I am inspecting the chtMultiRegionFoam -> multiRegionHeater Openfoam-5 tutorial case. I am interested in the following quantities
1) mass flow average temperature at the 'topAir' region's maxX patch.
2) to calculate heat flux i want to calculate the mass flow averaged enthalpy flux at the 'topAir' region's maxX patch.
In ther newer version i.e. OF5, I checked with the "postProcess -list" command which shows patchAverage and patchIntegrate and other relavant functionObjects but no such patchMassflowAverage functionObjects.
Any help regarding this with the commands will be helpful.
Thank you.
sprinter is offline   Reply With Quote
Old   February 13, 2018, 04:58
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I would think something along the lines of this should work:
surfaceFieldValue1
    type            surfaceFieldValue;
    libs            ("libfieldFunctionObjects.so");
    log             true;
    writeControl    writeTime;
    writeFields     true;
    surfaceFormat   none;
    regionType      patch;
    name            maxX;
    operation       weightedAreaAverage;
    weightField     phi;
    fields          (h);
You may need to adapt some entires for your particular case.
Regards,
Tom
lxufeishi likes this.
tomf is offline   Reply With Quote
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 10:30
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 10:40
Mass flow inlet with given temperature taalf SU2 3 October 15, 2015 14:25
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Difference between Mass Flow Average in CFX and Mass-Weighted Average in Fluent dasha ANSYS 0 December 21, 2012 04:41
