April 20, 2018, 18:01 |
postProcess file location
Nejc
Rep Power: 9 |
Hello.
The way OF solvers write postprocessing files is a little confusing. If I use run-time postprocessing all results will be written to a single file. But if I run postprocessing afterwards, each timestep gets its own directory with a single file containing a single value. is there a way to force either form of postprocessing into a more consistent way of writing results? I'd like to write a programmable filter but it might turn out a bit messy with all the confusion in postProcessing directories. Thanks! |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
