July 12, 2018, 11:59 |
Average velocity on a defined plane/volume
heru
Rep Power: 10 |
Imagine the following geometry. I want average of p and v fields for a selected area and volume.
The question is, how can I define an area and a volume? I know how select a full plane cuttingPlane { type surfaces; libs ( "libsampling.so" ); writeControl timeStep; writeInterval 50000; surfaceFormat vtk; fields ( U p_rgh alpha.water); interpolationScheme cellPoint; surfaces ( yNormal { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { basePoint (0 0 0); normalVector (0 1 0); } interpolate true; } Once the plane and the volume is selected, how can a get an v/p average of the selected plane each time step? Thanks |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
Average velocity of two different planes | niqbal | OpenFOAM Post-Processing | 6 | June 19, 2017 06:08 |
Monitoring Volume Average of Liquid Velocity Magnitude in a Bubble Column / Airlift | kevinlipps | OpenFOAM Post-Processing | 4 | May 19, 2016 05:59 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 08:35 |
Problem with time average tangential velocity in swirl flow. | lakhi | FLUENT | 5 | July 18, 2012 16:28 |
