August 9, 2018, 03:54 |
reconstructPar quits without an error
Nejc
Rep Power: 9 |
I have a problem with reconstructPar. I'm running a pimpleFoam case and reconstructPar quits without doing anything and it also doesn't throw any errors. This is the output: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | |*---------------------------------------------------------------------------*| |* OpenFOAM for Windows 18.06 (v1) *| |* Built by CFD Support, www.cfdsupport.com (based on Symscape). *| \*---------------------------------------------------------------------------*/ Build : dev-59be3e7 Exec : C:\OpenFOAM\18.06\cygwin64\opt\OpenFOAM\OpenFOAM-dev\platforms\cygwin64mingw-w64DPInt32Opt\bin\reconstructPar.exe Date : Aug 09 2018 Time : 08:48:55 Host : "***" PID : 11176 I/O : uncollated Case : *** nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reconstructing fields for mesh region0 Time = 0.00122947 Any ideas where the problem might be? Thank you! |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
